Gland Nut seal grease
emsvitil
Post by emsvitil »
Had to tighten up my gland nuts on my gauges yesterday to stop a leak.
This made me think that shouldn't there be something between the seal and shaft to lessen wear and help seal the shaft (if there was any, it's long, long gone)....
Is there some sort of vacuum grease that can be added that doesn't react with any of the common oils and refrigerants?
thanks
Ed
matthewsterling
Re: Gland Nut seal grease
Post by matthewsterling »
These kind of grease are available at online stores you can check it out.
