SD7V16 1214 pressures
Posted: Sun Jul 23, 2017 7:24 pm
Year: 2000
Make: VW
Model: Eurovan
Engine Size: 2.8
Refrigerant Type: R-134A
Ambient Temp: 70
Pressure Low: 50
Pressure High: 180
Only getting 6 deg temp drop from ambient out of the ducts. Noted that the high pressure valve is leaking when I remove the cap, but cap appear to seal when on. These do not have schraeder type valves, so I don't know that I can replace the valve (whole line is NLA) or just leave it.
Is it possible to have 50psi low side pressure and be underfilled?
Pete
Make: VW
Model: Eurovan
Engine Size: 2.8
Ambient Temp: 70
Pressure Low: 50
Pressure High: 180
Pete
