Airconditioner turns off but will not restart.
Posted: Wed Feb 26, 2025 2:40 pm
by markendee
Hi all, new member from Australia here.
Hoping someone may have experienced this problem.
My 2018 Impreza's airconditioner turns off when it reaches temperature but will not turn on again until car is turned off and cooled down.
The compressor clutch is not receiving power once it turns off.
I have spoken with many technical people but no one has experienced this issue.
We have regassed the system, checked clutch clearance and replaced the a/c relay.
A/c works perfectly until it turns the compressor off.
Something is preventing the signal to switch the compressor back on.
Any help would be very much appreciated.
Regards,
Mark.
PS I almost purchased a used controller to either fix or eliminate (the unit containing the controls and the ecu but discovered mine is a dual zone and all the s/h units were single. Mine is 72311FL301 and the units for sale were 72311FL311
Re: Airconditioner turns off but will not restart.
Posted: Thu Feb 27, 2025 1:51 pm
A couple of compressors are available for the 2018 Impreza, at least on cars made for the USA market: One for Manual A/C (scroll compressor, fixed displacement, with a clutch), and another for Automatic Temperature Control (piston compressor, direct drive, no clutch, variable displacement, with an electronic control valve).
You said you checked the clutch gap, so might it have Manual A/C (no "Auto" appearing anywhere on the controls)?
Posted: Mon Sep 08, 2025 4:39 am
by markendee
Problem fixed.
Posted: Tue Sep 09, 2025 9:20 am
What did you do to fix the problem?
Posted: Fri Oct 31, 2025 12:25 pm
by Davii
Im having similar issues with my 1997 Toyota Tercel at first the ac would work until the car got up to temperature then it would turn off and the ac light would start blinking and sometimes by playing with the ac switch it turns back on that was the case 2 months ago but now she doesn’t turn on the clutch doesn’t not engage I’ve re gassed the system 2 times and change the drier and pressure switch. But it doesn’t turn on please help
Posted: Fri Oct 31, 2025 4:25 pm
Kindly start a new topic for your questions.
Meanwhile, I have some additional questions:
How did you recharge the system, and with what type of refrigerant?
Add any oil? What kind, and how much?
Did you evacuate the system down to about 29.9 inHg (+/- 500 microns) before recharging it?
Did you scan the car for trouble codes?
