JohnHere wrote: Tue Oct 29, 2024 2:46 pm
If memory serves, the GM HT6-type compressor has been used for front and rear A/C (two evaporators) in the Chevy Suburban and some other vehicles. Whether the HT6 can handle
three evaporators, one main evap under the dash and two smaller evaps under the front seats, is open to speculation.
According to the specs, the compressor you mentioned has six cylinders and 164 cc's or 10 cubic inches of displacement. A Sanden equivalent, which has the benefit of no center case seam that can leak, has seven cylinders but slightly less displacement at 155 cc's or 9.5 cubic inches. I believe both compressors rotate in the clockwise direction when viewed from the front end of the clutch.
What year and model is your Lada Niva?
It's a 2014
I am having problems acessing this site through my normal internet connection. Sometimes I can manage to log in using www-proxysite.com
I have read about the HT6 reliability issues and kept digging.
The compressor I want to purchase is the SD7V16 163.1ccm³ and is variable and runs at roughly 35°F suction.
It has a cooling capacity of about 7.5kW at 3000RPM 0°Superheat and 10°subcooling
At 4000 RPM it's about 9.5kW increasing with revs.
I haven't found the max RPM limitations for this model yet. But I don't really rev my car so I can play with the pulley size.
And I can read the speed signal via arduino and just switch the compressor off when I rev the car.
Like this the compressor can spin 3000RPM in idle and be switched off for 5 minutes or so when reved above 7000 RPM.
That is one small evaporator in this link here and they just increased the price from 50$.
I read that some say "32 passes" for the coil and and this one here 22 passes
I will be looking for 32 passes.
this under dash evaporator here has 6 vents this could be standing behind the seats blowing upwards and a small one for under the dash.
I think from the data that I have seen that the compressor is capable of supplying 3 condensers, but I am not an expert.
Would the condenser be large enough, my electric fans are super powerful, the sound like sirens. people are turning their heads and ask what that noise is when they kick in.
The variable speed compressor will adjust the refrigerant quantity based on varying load, which can be regulated via fan speed?
I think some of you experts here have suggested that the main evap should be installed with orifice tube and not TXV and the others can have the TXV.
Or should they all have TXV's in a system with variable compressor?
And then have one accumulator in the main return line, or have two accumulators in series because if more refrigerant in the system?
The variable compressor system requires less refrigerant than a fixed compressor?
Edit: I was just removing links to external sites because it is not welcome I have read?
