I am in the process of adding A/C to my 1985 M1009, the military version of a Chevy Blazer. This is my first foray into vehicle A/C after repairing or re-engineering almost everything else on cars.
So far I have installed the blower/evaporator unit, the air box, and the under dash ducting from a civilian Blazer. The vacuum-actuated doors and baffles directing the airflow are working correctly and are sealing tight.
A 16" x 30" parallel flow condenser (biggest I can fit), receiver/drier, and a new evaporator core have been ordered. I will upgrade the engine driven fan, seal the ducting, and add two electric pusher fans in front of the condenser.
My plan for the rest of the system is as follows:
- Install a Sanden SD7H15 on the passenger side. When driven by the original crank pulley, the compressor will idle at 1280 rpm and reach 5760 rpm at engine redline. Is that OK or should I install a smaller crank pulley?
- Fit a TXV to the evaporator core. On the 4 Seasons website I can sort TXVs by tonnage and super heat. What would be good values for the evaporator that originally used a white OT with R12 and the GM pancake compressor?
- Obtain a fitting to connect the suction line to the #12 male O-ring evaporator outlet pipe. That would be a #12 female insert O-ring fitting, which does not seem to exist. Can I use a new accumulator to make the connection to the compressor and if yes, how much oil do I have to add for the accumulator? I could also cut the fittings out of the old accumulator and TIG weld them together.
- Splice in a second aftermarket evaporator unit to cool the rear of the vehicle. This unit has a thermostatic switch that I would like to wire to a solenoid blocking the liquid flow to the rear evaporator? What brand/model of solenoid would you recommend.
- What pressure switches should I install where and what should they control?
