Pressure switches
Posted: Fri Dec 28, 2018 6:05 am
Hello i am new to this site and retrofitting an ac system to an old vehicle.
it is using a gm style orifice tube with the big aluminium accumulator. i am wondering if it is possible to mount a trinary switch on the accumulator in place of the low pressure switch or if i require to insert a fitting that has the provision for a high pressure switch in the high side line.
i hope that someone out there can assist this amateur haha . thank you very much cheers.
