Using different size orifice tubes
Posted: Sat Jun 11, 2016 6:32 pm
I've got the A/C working in my '71 Plymouth Scamp that has a 2000 5.9 magnum swap. I'm using the '71 condenser and evap core with a '94 Ram compressor, accumulator and orifice tube. I had lines built to connect it all.
Pulled vacuum for 2 hours, then let it sit another hour. No leaks, so I charged it. Ram/Dakota calls for 32 ounces, but I'm not technically 100% Ram/Dakota anymore. I got 24 ounces in it and my low side pressure is too high.
One possible cause people have said is that it may be leaking past the orifice tube. I had a thought that since these orifice tubes are designed for a specific system setup, that maybe the purple Dodge orifice tube is too big for this system and allowing too much flow through it.
If so, can a smaller orifice tube from, say a Ford, be installed to slow down the flow and lower my pressure on the low side?
