AC problem 2003 Chevy Silverado
Posted: Wed Jun 01, 2016 5:02 am
AC compressor will not turn on. Here is what we have checked
coolant is fine
AC works if you pull the relay and jump it.
relay has been swapped with a known good relay.
climate control head has been changed.
pcu/ecu has been changed
plugging a diagnostic computer in to the truck never shows the AC button being pressed
ac button does light up
fuses are all good
i am thinking that it must be a wire somewhere, but where do I go from here? I know the wiring from the underhood fusebox to the AC compressor is good because if we jump the relay it turns on and blows cold air
coolant is fine
fuses are all good
