'71 Plymouth mixed with '94 Dakota
Posted: Thu May 26, 2016 7:55 am
I have an '71 Plymouth Scamp that I have done a 2000 5.9 magnum EFI swap into using a '94 Dakota V8 harness and '94 Ram 5.9 computer. Now I'm trying to come up with a working A/C system and have some questions about how the two systems are routed. I'm definately not an A/C expert and won't know alot of the abbreviations and terms you guys may use, so don't hold that against me!
What I plan on using are the '71 style Evap core, expansion valve and condensor with the '94 compressor and dryer, then having hoses made. When looking at the routing of the two systems, I discovered a difference, and this is where the question comes in.
The '71 system goes: compressor -- condensor -- dryer-- expansion valve -- evap core -- back to compressor.
The '94 system goes: compressor -- condensor -- expansion valve -- evap core -- dryer -- back to compressor.
My question is: Does it matter where the dryer is in the system?
