Compressor?
Posted: Sat Nov 12, 2016 12:29 pm
by walth
Static charge 88psi @ 80deg outside temp, at idle the compressor goes from 90psi to 110psi, the low side goes from 70psi to 30psi. Cycles every 10 seconds. Compressor replacement time? 2002 Blazer.
Re: Compressor?
Posted: Sat Nov 12, 2016 3:54 pm
Does it have the correct refrigerant level? With the low side dropping you have pumping action going on!
Re: Compressor?
Posted: Sun Nov 13, 2016 12:03 pm
by walth
I guess the best way is to have it evacuated and weighed then refilled. Unless there is a way to determine how much to add.
Re: Compressor?
Posted: Sun Nov 13, 2016 1:01 pm
You must have the correct refrigerant level in to determine any issues you may be having.
