87 Chevy truck issues
Posted: Mon May 16, 2016 1:58 pm
My original thread is in the archives, so here is the background -
87 Chevy R30, CC dually that I recently purchased. Previous owner started a 134a conversion. System not working when I purchased it. A6 compressor "looks" new, as does receiver/dryer.
As I was unable to confirm what oil was in it, or even if there was any oil in it, I pulled the receiver and nothing drained out. I pulled the compressor and also no oil came out. Blew air through condenser lines and got no oil residue coming out. Added PAG 150 to the compressor, a little in the receiver, and put it all back together and pulled a vacuum. Vac'd for 30 min and let it sit for 30 min and it it looked like it maybe was loosing a little but I figured that could have just been my fittings.
So, gave it a shot of UV dye, then started charging it. R12 capacity was 52oz, so I targeted 44 oz of 134a (just short of 4 12oz cans). First can in and pressures came up enough for compressor to start cycling. Second can in and pressures started getting up to where I would expect them to be when full when I only had about 20oz total in, then suddenly pressures dropped, and came up steadily from there as the rest of the second can went in. Got 3rd can going and just about the time the pressures were up high enough that the compressor was running steadily, pressures all dropped again to 30-40 on the low and 100-120 on the high and would not go above that as I finished the 3rd can. I checked all fittings and joints with a black light and no dye was visible. None around the face of the compressor either. So I shot a couple ounces more dye in, then pushed in the 4th can. Low side pressures got up to 80-ish and high up to almost 200 and then got a horrible whistling noise and pressures dropped. I checked everything under the hood and no dye was visible anywhere.
So at this point I am thinking evaporator leak. Anything else that I might be missing before I dig into it?
Also, the compressor sounds horrible - like there is someone inside banging on the case with a hammer. I don't remember A6 compressors sounding like that.
Thoughts? Advice?
Thanks!
Thoughts? Advice?
Thanks!
