AC leak 2003 Honda CRV
Posted: Sat Sep 03, 2016 2:43 pm
Hi All,
I've got a 2003 Honda CRV with a substantial refrigerant leak. I have pushed UV dye through the system and am still having trouble finding the leak, but it's audible while the system is under pressure. It will not hold any vacuum on the low side for more than half a second, but the high side holds just fine. Is it possible that there is an internal leak inside the compressor that I can't see with the UV dye? The compressor kicks on and runs fine while pushing refrigerant through the low side port, however it leaks out so quickly that the system does not stay pressurized for more than a second or two.
Any ideas on possible culprits would be appreciated.
Thanks!
Connor
Thanks!
Connor
