Fitting/Hose Compatibility Issue
Posted: Tue Aug 16, 2016 4:41 pm
by 69-er
I am upgrading an old 1966 C10 factory AC system using new components where possible. I have a parallel flow condenser, and an Everco #58098 compressor to replace the A6. I will be converting to 134A.
My problem now is, what to do with the original evaporator? It looks usable and is leak-free but has the barb fittings. The condenser and compressor has fittings for beadlock hose fittings. How should I go about adapting the beadlock hoses to the evaporator?
A few years ago on my 83 Camaro I had the compressor manifold barb fittings cut off and beadlock hose ends welded on for use with beadlock hoses.
Is this an option?
I did find a new evaporator that appears to have fittings instead of barbs, but now it's starting to get a little expensive! As old as the original evaporator is, maybe I should just bite the bullet and get it.
Suggestions please?
Re: Fitting/Hose Compatibility Issue
Posted: Tue Aug 16, 2016 5:54 pm
by Dougflas
If you can the cost, I would not use a 50 year old evaporator.
Posted: Wed Aug 17, 2016 1:44 pm
by 69-er
That's what I am starting to think. Later down the road, when the new one is still working, I'll have forgotten about the cost! But I sure as hell would have remembered trying to save a buck if I used the old one if it ever failed!
Anyway, if age or reliability weren't an issue, what would be the other alternatives?
