POA Valve test with results
Posted: Tue Aug 16, 2016 11:08 am
I just finished testing 2 POA valves one that's NOS and another that's been used.
When I tested the used one, I slowly cranked up the pressure on the inlet and when It swung past 30lbs to about 40 or so ( wasn't paying attention to the exact point) I heard a pop and a went back to 30 lbs and stayed there. I could repeat it over and over with the same results.
On the NOS valve, as I turned up the pressure it would stop right at 30lbs with no POP sound. Or it was so low I couldn't hear it. I did it several times with the same result.
Is the NOS POA working correctly?
Thanks!
Ed
Thanks!
Ed
