How do I tell type of oil in system?
Posted: Mon Aug 15, 2016 7:42 am
by Emdoller
I have a 69 Camaro that I recently purchased. The POA valve had a r134 connector screwed into the old r12 low side port and the hose that should have had a high side port didn't. I assume this means it was converted to r134.
I noticed a small oil leak in front of the compressor but nevertheless the car was blowing some cold air. This weekend that stopped.
I assumed that the car was converted to 134 and tried adding some to see if I could get it cold. Didn't really work. It might have been because the r134 to r12 adaptor was bad.
I then decided to pull a vacuum and see if it would hold while at the same time putting the correct high dude hose on.
It hold a vacuum for a few hours and then went to zero. Not sure if it's the compressor, my new hose, or something else.
I figured since I've gone this far I should get the compressor rebuilt.
So here's my question: how do I tell what type of oil is in the system? I will need to add it to the compressor. That is, is there a way to tell the difference between PAG, ester, or POE?
Thanks!
Ed
Re: How do I tell type of oil in system?
Posted: Mon Aug 15, 2016 8:21 am
Emdoller wrote:So here's my question: how do I tell what type of oil is in the system? That is, is there a way to tell the difference between PAG, ester, or POE?
An analytical chemist (like me before I retired) could use FTIR to determine easily the oil type by comparing to standards. I did that with a few new or rebuilt compressors to determine whether PAG or R-12 type mineral oil had been added. There may be other ways, do a Google Search.
FTIR is Fourier Transform Infra-Red spectroscopy
Posted: Mon Aug 15, 2016 9:04 am
by Emdoller
I tried google. Can't seem to find anything.
Posted: Mon Aug 15, 2016 9:35 am
by wptski
Cusser wrote:An analytical chemist (like me before I retired) could use FTIR to determine easily the oil type by comparing to standards. I did that with a few new or rebuilt compressors to determine whether PAG or R-12 type mineral oil had been added. There may be other ways, do a Google Search.
Yeah, we all have one in our garage! :mrgreen:
Posted: Mon Aug 15, 2016 10:48 am
Assume the worst with a sloppy half-way conversion. It probably has a double dose of oil, and a dessicant that is not compatible with 134a.
You need to break the system down and flush the evaporator & condenser back to bare metal.
The POA valve needs to be calibrated for 134a,or you need to stay with R12.
Probably best to pressurize the system with a few ounces of 134a & finds the leaks before you tear it down.
Posted: Mon Aug 15, 2016 4:43 pm
by Emdoller
Thanks. I was thinking the same thing as I doubt the POA was calibrated. I've never flushed a system... How hard is that to do?
Ed
