Fresh air infiltration while in Recirculate Mode
Posted: Wed Sep 12, 2018 10:18 am
Hi
I'm working on a 1995 Alfa 164 LS. I think the problem is that I'm getting external air (fresh air) into the HVAC system when it should be in recicrculating (RECIRC) mode.
I'm looking for some way to test that the airpath through the HVAC system is sealed when the system is set to RECIRC.
When I suspect vaccum leaks / false air in the intake of a car engine I use my smoke testing machine. Unfortunately it uses baby oil to produce its smoke, and that has a disintive aroma, so I can't see using it in a HVAC system.
Is there some kind of perfume free smoke test, that you can use on a car HVAC sytem?
Unlike most Italian cars, the 164 produces reallly good AC, when the system is working. The HVAC system in the 164 shares many parts with the SAAB 9000. I've replaced the heater blend doors with new NOS doors, and the CIRC/RECIRC flap seems to seal tightly, but still I think I'm getting external air into the system.
All assistance welcomed
