2001 Pontiac Grand Prix A/C Noise after new compressor
Posted: Sun Aug 05, 2018 10:27 am
I really could use some help on this mystery..........
A month ago I replaced the following:
AC Compressor - ACDelco
AC Receiver/Drier - Toughone
AC Orifice Tube - Toughone
AC Condensor - Toughone
Because I replaced all of that and i flushed out the lines I added 9oz of PAG150 per references found here, http://www.4s.com/media/4981741/Four-Se ... -Guide.pdf, and here, http://www.techchoiceparts.com/refriger ... es/pontiac.
I vac'd the system for 15 minutes and let it sit overnight to check for leaks. Once satisfied it was leak free I vac'd the system for 45 minutes and then charged the system with 2.2 lbs of R134 per the under hood sticker using low side port and a set of gauges. Note that I use a large 30lb container of R134 and a digital scale to precisely measure the amount of refrigerant installed.
The ac worked awesome but when the compressor is engaged and the rpms exceed 2000 a whirring or humming noise came from the compressor. It got increasingly loud as the rpms rose. It is most definitely the ac system as the sound immediately stops when the compressor is disengaged.
This is not the first time I have charged an ac system, but just to be safe I had a shop evac the system and re-charge it using their "professional" equipment. The noise persisted and the shop agreed that I simply got a defective compressor. At this point they removed all of the refrigerant so that I could replace the compressor under warranty.
I just installed another brand new ACDelco compressor and then followed that same procedure above to leak test, evac and charge the system. Note that this time I drained the PAG oil from the first new compressor and measured it. I added the measured amount of new PAG oil to the second new compressor before installing it.
Once again the ac system works great, but the whirring noise is still present. For reference the temperature at the time of the second system charge was 80 degrees with low humidity. After the charge the low side pressure was 43 and and the high side as 175. Also, I did note that the system stopped inhaling refrigerant about 3 oz short of the 2.2lbs.
I know it's possible that I got a second defective compressor, but I feel it's unlikely. Any thoughts?
