Compressor works then stops for a day or two
Posted: Tue Jul 10, 2018 1:43 pm
Good Day All. This is my first post here and I hope I can find some guidance.
I have a 96 Buick Roadmaster Estate Wagon which I charged the system with autozone refrigerant. I did not use a manifold gauge set at first. AC blew pretty cold. I added a bit more freon a few days later. I turned the car off to go to post office and the compressor was froze. About two days later, I hopped in and turned on the ac. I had purchased a manifold gauge set and check pressures. Low side was about 40 and the High side was like 100. 80 degree day. I know the high side was low. So i pulled the O tbe out and it was clogged bad. No Metal Shavings Tho! Just gunked up oil (grey/black in color)
I have since changed the drier which had a bunch of oil in it ( I cut it open to see how it looked inside). I did screw up and poured the oil out thinking it should not be there DUH!!!!!!! I bought one of the Harbor Freight Pressure/Vacuum Pumps that uses air pressure. I am able to pull about 24 inches . Now, my questions are these: How much oil should go back into the drier and do the symptoms I Described Indicate a Failed Compressor?
Blessings To All And Thank you For This Forum!!!!
