Black death? Dry soot?
Posted: Mon Jul 09, 2018 8:06 am
1987 Chevy R30 truck. H6 compressor was brand new about 18 months ago. Entire system had been replaced with new components back then - evap, condenser, accumulator, compressor and all lines. Used 8oz of PAG46. System worked great until last winter. Discovered a leak between the case halves on the H6. Finally got around to getting a replacement compressor while it was still under warranty.
Pulled off old compressor and went to drain it to see how much oil to add back in. No oil came out of compressor. Noticed discharge port was black and sooty. Pulled accumulator to see how much oil was in there. None.
Pulled orifice tube. First thought was "I thought I put in a blue, not a black". It was black. Not wet and chunky black like black death, but dry and sooty. I wiped some off and snapped a picture -
I was ready to put in a new compressor, orifice tube and accumulator, and add back in however much oil came out, but now I'm not sure how much oil to add or if the system needs a complete flush to remove whatever this black stuff is. Again, there are no signs of metal or anything else, and the black stuff is totally dry like soot.
Question 1 - where is my oil?
Question 2 - what is this black stuff?
Question 3 - do I need to do a full flush of the system?
