Scampo77 wrote:Sorry.... Not "read" the engine..... It should have said "when I rev up the engine" auto correct turned rev into read.
Got it. Happens to me as well
Scampo77 wrote:I don't know what a CCOT or a TVX system is.
Clutch Cycling Orifice Tube, or Thermostatic Expansion Valve
Scampo77 wrote:I welded the hole closed in the condenser to get it working until the new condenser gets here from Europe.
That might be part of the problem, especially if any debris found its way in and/or if the repaired area is still leaking a little.
Smart cars like your year and model are known to have persistent refrigerant leaks. Are you sure that you still have 450 grams (15.9 ounces) in it? Because this system holds so little refrigerant, just a couple of ounces lost will result in performance issues. Maybe the hole repair is still leaking, or it could be losing refrigerant someplace else that you haven't noticed yet. Revving the engine and seeing the low pressure drop like that could mean a metering device issue (CCOT or TXV, whichever it has).
One other thing: I strongly advise against using Red Tek or DuraCool in it and staying with plain old R-134a. I believe that these products, readily available in Canada, are essentially propane (highly flammable!), and might also contain sealer.
You definitely don't want any sealer in your A/C system.
In the USA, we don't normally evaluate a mobile A/C system using superheat and subcooling. We generally leave those methods to the residential/commercial HVAC techs. Charging by weight using the proper refrigerant and an accurate scale, measuring / evaluating high and low pressures, and gauging vent temps is essentially the way we do it here. So I'm a bit out of my league with the former.
At this point, I think I'd wait until the new condenser arrives. Then, recover whatever refrigerant is in there, install the new condenser, along with a new receiver/dryer and all o-rings, evacuate well, recharge to spec with plain R-134a, an ounce of the appropriate oil, and a little UV dye. With the dye pre-installed, you can then leak-check the system later if you discover that it's still losing refrigerant.
