Mechanical Fan AC delay
Posted: Tue Jul 03, 2018 8:49 am
I have a 1999 Lexus LS400 w/ viscous cooling fan and 1 factory electric pusher fan on the condenser. I have just replaced the viscous coupling so I know that it is working properly. I live in Pheonix where daily ambient are approximately 105-110 right now. My car sits in the sun all day at work and is very hot inside when I return (I use a sunshade, crack windows, and have very dark tint).
I have noticed that after startup, the AC doesn't work particularly well at idle for at least 5+minutes until the engine has warmed up and the viscous fan engages based off radiator temperatures.
Running some quick numbers, assuming high side pressure is around 300psig with R134a, condensing temperature is about 160 degrees F. That means the air coming off the condenser is at some temperature cooler than 160 degrees, which doesn't seem like enough to engage the fan.
I did observe this, I let the engine idle for 7-8 minutes with the ac on and only then did the radiator get hot and cause the viscous fan to engage (it was audible). At that point the AC began to cool better. The electric fan was on the whole time but doesn't move a whole lot of air. It was also on low speed (it can be on low or high speed depending on what the ECU wants).
Is this working as designed? Is there any way around this? Ideally the mechanical fan would engage with the AC running even if the engine is not yet fully warmed up. I was considering getting a remote start to pre-cool the car but if the fan doesn't lock up for the first 5 minutes anyways it might be a waste. Couldn't this also run high side pressures up dangerously high?
Even when I drive off right away, the stop and go nature of my commute makes the first 5 minutes or so very hot inside the car.
