BMW E30 R134a conversion looks normal static/idle but hi-side goes HIGH over idle
Posted: Sun Jul 01, 2018 1:36 pm
I did a major r134a conversion to my 1989 325i to R134a
Rebuild compressor (came with 3oz PAG46 oil in it, said to add 3.75oz additional oil which I did to the rec/dryer)
New parallel flow condensor
New expansion valve
New rec/dry and pressure switch.
Some not all new lines. All new green o-rings
No work to evaporator.
Pulled 30hg vacuum for an hour, checked no leaks an hour later.
Known issues:
*the condensor fan is presently broken, new resistor coming soon*
*the expansion valve has not been re-insulated and is presently exposed (plastic cover not reinstalled), I have the correct insulation tape coming soon*
Available specs from the compressor / BMW call for approx 32oz R134. I added (2) 12oz cans then read the pressures with A/C on, interior fan on full speed.
@90degf/60% humid I see:
Static: 115psi hi 115 psi low
Idle: 250psi hi 50psi low
When I build revs to about 2000 and hold them there I see the hi side creeping up, up up then shut it down around 350psi. Would this behavior be caused by he lack of condenser fan? I am not sure how quickly the condensor 'heat soaks'. I am also not sure exactly how sensitive the expansion valve is to airflow around it (not being covered in insulation tape per the factory and missing its plastic condensate cage).
Thank you all for any guidance. I do a lot of work on my cars but A/C is a mystery!
New expansion valve
Known issues:
