75psi on high and low side
Posted: Sat May 19, 2018 5:09 pm
Vehicle: 2005 Acura RL
Problem: Gauge reads 75psi on both high and low side after adding 1 can of R134a
Prior action: Have replaced compressor twice and expansion valve once
* First compressor replacement was because original one was leaking. This was a cheap Chinese compressor.
* Second compressor was after installing first replacement the pressures were equal: same as above. This is an expensive Denso compressor.
* At this point, the only thing I knew to do was to replace the expansion valve. But, even after this, the pressures are the same.[/list]
At a loss for what to do next. Will appreciate any help. Thanks.
