Don't know how much oil I lost
Posted: Sat May 12, 2018 12:33 am
I am in the process of dropping the drivetrain out of a 2008 Sienna and was working to detach the compressor from the engine in order to _not_ have to discharge the A/C, but I loosened a wrong bolt and blew out all the refrigerant.
My A/C experience is limited to topping up and basic diagnosis. Otherwise, 40+ years of working on cars.
I have a decent manifold set and I'm not worried about evacuation and recharging, but - I don't know how much oil I lost.
From reading online, it looks like the way to do it right is to disassemble everything, flush the lines and heat exchangers to remove oil, drain the oil from the other components, and then reassemble and fill with the manufacturer-specified amounts of oil.
This van has rear A/C, so it has miles of lines. Both my air compressors are 300 miles away, so I guess I'll have to buy a cheap compressor for this.
So...
1) Is flushing really the only reasonable way to solve this? Anybody got a magic method for estimating the oil loss?
2) If DIY flushing, does it go like this?
- remove compressor, rec/dryer and valves and drain the oil from them
- run a flush through the pipes going to/from the main evaporator
- run a flush through the pipes going to/from the rear evaporator
- run a flush through the condenser
- reassemble with new r/d, orifice tube, and seals
- evacuate & leak test
- recharge
3) What kind of cfm@psi do I need for the flush?
4) What flushing equipment and chemicals do you recommend?
Thanks in advance for your help.
So...
- recharge
