Stuck ac line (but not the nut, the junction)
Posted: Mon May 07, 2018 10:59 am
Hello everyone.
I'm the owner of a beautiful 1991 Mazda Rx7 Convertible.
I'm restoring the ac system changing all the o rings.
Al the lines came off easily. The only line giving me a lot of trouble is the one that is on the enter side of the condender (the one that is from the high pressure side of the compressor).
I had not troubles to unscrew the nut (all the nuts of the system are in perfect state, no corrosion), problem is that the junction is freezed. I tried to pullout the junction but it's blocked. I think perhaps that the o ring inside is melted or there was a small oxidation melting.
What can i do now? I sprayed a lot of penetrating oil in the small slot beetween the junction but the joint is so accurate that i can't insert even a small screwdriver into it (it will ruin the coupling) for pry the joint.
I don't want to cut the line. Can you help me please?
Thank you very much.
