AC low side over 100#
Posted: Thu May 03, 2018 9:11 pm
I have a 73 Mustang Mach 1. I got the car about thirty years ago. It had AC stock but I got it with no engine. So I pieced the AC together and charged it with R12. I got a 30# cylinder back when it was available. I still have about half of it.
The car has not been used much the last few years. I am prepping it for a road trip. I assumed I would need to charge the AC. The compressor cycles by a temp switch in the evaporator. When the clutch is disengaged both gauges read about 150#. When the clutch engages low side drops but stays well over 100#. It is blowing cold air. The engine idles at 1K RPM. When the clutch engages it drags the engine about 200 RPM.
I piece together AC systems. I have no way of determining proper charge by weight. So I charge until the low side is 30#.
So why is the low side so high? I have difficulty believing that I massively overcharged many years ago, and it has held.
I am in the process of replacing all my old compressors with 508s, but have not yet scheduled this one.
