Custom A/C system diagnostic
Posted: Mon May 02, 2016 12:57 pm
Hi all,
I have pieced together an A/C system for my restomod truck and I am seeking some diagnostic help with pressure and fluid volume.
Here are the vehicle details:
1971 Ford F100 body on a 1999 Mercury Grand Margquis chassis and drivetrain
1971 FoMoCo Integral A/C & heat box with 1971 FoMoCo evaporator
1999 Grand Marquis compressor, condenser, receiver/drier & pressure switches
1999 Grand Marquis 2 speed electric fan (fan does switch to hi speed when A/C is engaged)
Custom A/C lines (around 8' total length of #10 flexible hose)
GM type Orifice tube repair kit modified to house orifice tube
White .072" orifice tube
The ford/Mercury manual states the following for "standard operating specs"
80 deg. ambient temp at 50-70% humidity
engine RPM 1200
Lowside pressure: 22-45
Highside pressure: 125-235
My current readings:
Cold static pressure: 110psi
at idle 800 rpm pressure: 39psi lowside 170psi highside
1200 RPM: 32psi lowside 200psi highside
2500 RPM: 25psi lowside 225psi highside
1500 RPM while driving 55mph: 25psi lowside 210psi highside
Evap inlet temp: 66 deg
Evap outlet temp: 69 deg
To achieve these pressure I had to add 68oz of R134a... I know I added a LOT of extra capacity with the large and very long hoses but it seems like a lot of freon! I tried driving the truck with 60oz but after a mile or so the lowside pressure would drop below 22psi and the pressure switch would disengage the compressor and begin a "short cycle" issue.
My questions:
1. Is there a way to accurately measure my system and come up with a mathematical solution for the amount of freon required? or is my method of using the evap inlet & outlet temps combined with idle and driving pressures the best route?
2. Does the lowside pressure drop seem "normal" from idle to driving?
3. Does the highside pressure increase seem "normal" from idle to driving?
4. Since the original install of this system I have been informed that the Grand Marquis came factory with an orange 0.57" orifice tube diameter, should I remove the .072" that is in there now and replace it with a .057" tube?
5. Do you have any advice on any changes I should make? (I.E. Orifice tube diameter, pressures, etc...)
engine RPM 1200
My questions:
