Side can tap
Posted: Wed Nov 08, 2017 8:25 am
bohica2xo wrote:If you go with a vintage can, a side tap is a good investment.
bohica - I've thought about getting/using a side can tap, I have separate top tap units for R-12 and for R134a. Exactly why do you like that type better? thanks.
Re: Side can tap
Posted: Wed Nov 08, 2017 10:11 am
Cusser:
After years of fumbling & leaks with the old R12 pierce valves I bought a side tap. I had a can of R12 turn in to a rocket when the tap let go of the top rim as I was piercing it - that was the final straw.
1) No pierce & retract for flow - the pierce needle stays swaged in the hole as long as the tap is installed. Not a great seal, but it fully supports the secondary rubber seal against the can.
2) It fits everything. I have had a 134a can with threads so bad the valve would not even screw on it. Side tap no problem. It can't fly off - it wraps around the can. Want to access other aerosols at high volume? No problem. Got an old 4 ounce can of oil & dye? done.
3) You can pierce at the lowest point on the can, where the rim supports it. Then you can set the can on a flat surface & draw liquid. By drawing liquid you solve the freezing can issues. Throttle the service valve if you want gas, the manifold gets cold - but the can stays at full pressure.
One of the reasons I recommended it to the M-B owner is 30 year old cans. The can OD is the same, and the side tap will fit. I can't promise that there is a compatible top tap in his tool box.
Re: Side can tap
Posted: Thu Nov 09, 2017 9:55 am
Re: Side can tap
Posted: Sat Nov 11, 2017 6:08 pm
by emsvitil
Both those fittings look like they're for R134a hoses.
Is that what I'm seeing, or is it for both R134a and R12?
Re: Side can tap
Posted: Sat Nov 11, 2017 9:16 pm
Should be both threads - can't see why they would offer two of the same thread on one unit.
This one has both for sure
http://www.ackits.com/85530-3-in-1-side ... dard-31770
Re: Side can tap
Posted: Sun Nov 12, 2017 8:42 am
The first one (above) sure looks like both R-12 and R134a to me !!!.
Re: Side can tap
Posted: Sun Nov 12, 2017 9:20 am
R12 & R134a.
Re: Side can tap
Posted: Mon Nov 13, 2017 8:28 pm
by emsvitil
I'll be honest here.
You need to do something about your shipping costs.
$16 to ship to California is WAY HIGH.
Re: Side can tap
Posted: Tue Nov 14, 2017 2:42 pm
emsvitil wrote:I'll be honest here.
Call UPS. Its thier rate.
