Why aren't V7s used everywhere?
Posted: Sun Sep 24, 2017 11:03 am
Year: 1989
Make: Chevrolet
Model: G20 (full size van)
Current AC: R4 with R12
Front air only (no rear)
Serpentine belt on steel mounting brackets (steel used in 88, 89, and maybe 90)
About six years ago, I installed a new R4 compressor on my full size Chevy van. I thought all the leaks were repaired but apparently not. It works fine for the summer but by the next summer it needs to be topped off again. R12 just doesn’t seem like a viable option for me anymore. For the last two summers I haven't used the air and that's no fun in the South. The backstory is that the AC in this van has never worked "well" in around town driving. It's been that way since new (when I bought it).
Now seems like the time to switch to R134a. If so, then I will replace the accumulator, orifice tube and the condenser. Unless someone knows of a drop-in replacement parallel flow condenser it seems that new refrigerant hoses might be required. It might be smart to replace the fan clutch too.
The question is will replacing the compressor improve the AC performance? If yes then now would be the time since most of the front end of the van will come off to replace the other parts. I have tried to read everything I could about replacing the R4 with a Sanden, Seltec, V5 or V7 compressor. All seem to have pulleys with a 119 mm diameter. The plus for the Sanden and Seltec is that a R4 conversion bracket exists. If there is one for the V5 or V7 I haven't found it. Fabricating a bracket for the V5/V7 is not the problem. It's designing the bracket so the pulley is in the correct location that's the problem. It seemed like the Sanden or Seltec would be the clear winner. That's until I saw the performance graph for the V5/V7 that bohica posted in the link below.
https://autoacforum.com/viewtopic.php?t=183
Sanden has performance graphs for the SD7H15 and the enhanced SD7H15 at the links below.
http://www.sanden.com/objects/SD7H15_Performance.pdf
http://www.sanden.com/objects/ESD7H15_SES.xls.pdf
From my reading of the graphs here are the results at 1000, 2000 and 3000 rpm compressor speeds:
Cooling Capacity [kW] 1000 rpm 2000 rpm 3000 rpm
V7............................. 4 ........ 8.5 ........ 12
V5............................. 3+ ....... 7.5 ........ 11
SD7H15 Enhanced.......... 3+ ....... 6.5 ........ 9+
SD7H15....................... 3 ........ 5.5 ........ 7.5
How would the R4 compare with these four compressors? From the numbers, at 1000 rpm the V7 produces 1 kW (~3400 Btu/hr) more cooling than the SD7H15 or 33% more. And it continues to outperform at higher rpms. The V7 looks great on paper but is this a case of "lies, damn lies and performance graphs"? So much for the theory. How do V7s perform out in the real world? Why aren't V7s used "everywhere"?
Steve
Make: Chevrolet
Steve
