98 Buick Park Avenue, AC low pressure too high
Posted: Mon Aug 28, 2017 8:42 am
1998 Buick Park Avenue Ultra
Issue started with no cold air. In the past year I have had issues with that & have added stop leak and freon. A couple times I again added freon when it would start not working again. The last time, was several months ago & it has held quite well.
I thought I needed to add freon again but when I put the Walmart gauge on, it showed in the red.
From there I have tried the following:
I went to AutoZone & got a manifold gauge set. Both high & low pressure registered about 88 psi (static). I honestly don't remember what it was with the AC on.
I went back to AutoZone & got a vacuum pump. My thought was that maybe all the crap I was putting in there in the past caught up to me. So, I ran it down to -27. I had bought 3 cans of freon & one 8 oz bottle of PAG 150 oil (book called for 36 oz freon & 8 oz of the PAG 150 oil).
I read how to put the middle (yellow) line in the bottle of oil & open the high side valve to suck the oil into the system, which I did. Then, using my Walmart gauge again, I started to add the freon but it again went into the red.
Observations & things I have tried (besides the above) are:
1. The clutch does not kick in.
2. I shorted the relay which did cause the clutch to kick in.
3. I measured the voltage on the connector to the compressor & it showed something like .4 volts? I thought this was the problem until I jumped the relay & it worked.
4. An issue I keep seeing come up is the low pressure switch. The trouble is, I can't seem to find that. There are multiple places that tell where it is, but I must be completely blind because I can't find it.
5. I also removed (will buy new ones tomorrow) the cabin filters & my goodness, those things were disgusting.
6. I checked all the fuses.
My question then is, does all of this sound like it could be the low pressure switch? If so, can someone please send me a picture or something that will tell me where it is on this vehicle?
Thank you all in advance for any guidance and/or help you can give me.
