Electric Fan Wear
Posted: Mon Aug 01, 2016 12:56 pm
Question for you gentlemen. I cannot really find any evidence online or anywhere for that matter that electric fans suffer from significant wear or slow down over time. Can you clarify that for me?
I posted a few years ago regarding my 1990 Civic Si that I did a full parallel flow conversion on and I'm still having extremely high pressures (38 low and >250 high) and craptastic 60f-65f vent temps at an idle. This is with the car completely closed up at 1500 rpm with an umbrella and sun shade over the car on a 90f-95f 75% humidity day. While driving, though, the car does 38f-45f at the vent when I (did) have the evac and charge perfect.
I just picked up stock fans from the junkyard with the shrouds completely intact in the hopes that bad shrouding is my real problem here. I also suspect that perhaps my fans are worn down and slow from age? I believe they are literally the original motors.
Also, my compressor has been ticking since I bought it from ebay (unfortunately). Does the new Matsushita compressor from the Ackits website have some sort of warranty? I believe I have a shaft seal leak or my lead plug blew out on the compressor because my charge is only lasting a day now and there are no leaks anywhere else with apparent UV dye. I'm seriously considering getting rid of the damn car because it's too hot in FL.
I just replaced the Evap again with an OEM NOS Honda unit complete with TXV. All o-rings are new. Drier is new. No signs of metal shed through the system. The oil is BVA Auto 100 from my P-Flow conversion a few years ago and it's still bright neon green.
Another question. How much of a difference does fresh oil in the vacuum pump make? I bought a whole quart of pump oil and that was when I had the system perfect after I swapped it out. The air was cold within 10 seconds of the car running and would pull down to 40f while moving above 30mph. My Mastercool high side gauge fitting also isn't really reading anymore on my car only. I replaced the fitting and it will still only read while it's in a vacuum, not while charged.
Sorry for the essay, but that should answer most of the questions regarding the car. I really appreciate the help. Over the years this site has helped me fix over 15 A/C systems in cars. The best one was my friend's 2002 Sunfire and it would literally pull 40f no matter what.
