Here are the stats, what's your diag
Posted: Sat Jul 30, 2016 11:42 am
by jknave
Hey there,
I'd like to just give you the numbers, what would your diagnosis be? I have my own guess(es), but I'd like to hear yours first. I can provide more detail if you want it.
R-134a, dynamic test:
Low side: 25 psig
High side: 150 psig
- Engine overheats as ac runs when engine is idling while car is stationary
- cabin air duct temp got as low as 55° - 50° F
- ambient high of 87°F, likely higher in engine bay of course
I'm going to find a power washer today and blast the bejesus out of the radiator and condenser, as a first step regarding the overheating issue. I may need to install another efan in front of the condenser, since I already replaced this car's belt fan with an efan mounted behind the radiator. Condenser is mounted directly in front of the radiator.
Thanks!
Re: Here are the stats, what's your diag
Posted: Sat Jul 30, 2016 11:02 pm
Yeah, the 1985 Yugo tended to act up like that. Drink more vodka, you won't notice the overheating - it says so in the owner's manual on page 4
Posted: Sun Jul 31, 2016 1:36 am
by jknave
Not bad, only 1 year off... this is an '86 Volvo. ;)
Posted: Tue Aug 02, 2016 11:22 am
by jeepsj
Replacing belt fan with e-fan was probably a mistake. Factory mechanical fans will be superior to your typical chain-auto-parts e-fan. The fact that the engine overheats tells me you are not moving enough air through the radiator.
Posted: Sun Aug 07, 2016 10:10 am
by jknave
Yeah, I was wondering... I removed the fan and viscous clutch because the pulley studs started shearing off one day. Temp's been fine, but the AC wasn't working then.
I think I have a working clutch somewhere, and the original fan shroud (which may help even further), I'll switch things out and see how it goes.
Any thoughts on the pressures or low side temp? Or maybe wait to until heat exchange efficiency is restored?
