R12 Charging Problem
Posted: Fri Aug 11, 2017 5:42 pm
Been working on the 1992 Buick r12 AC for over 2 months now - I have studied the charging procedure over and over - every single piece of hardware is new - held great vacuum . Did all my pre-checks....Today was the big day to finally charge and then ...flop..
With the car off, I charged one 12oz. R12 can as a liquid on the High side (HR6 Compressor). no problem there. Turned off the high side valve and then connected 2nd can to the Low. Turned the car on - Compressor started cycling. It seems that as soon as I open the Low side valve for the 2nd R12 can to flow in , its stops cycling and then both pressures slowly climb/equalize at 110psi - its about a 100deg. here in Dallas. ..Even though I put the can in hot water - upright- seems like no more gas is flowing , compressor is doing nothing and gauges are equalized at 110...I tried to jump the Low Pressure Cutoff switch just to see if the clutch would engage - but nothing happened.
hope someone can assist..thanks
