Hi low side with proper amount of refrigerant
Posted: Mon Aug 07, 2017 9:41 am
I have an Infiniti i30 1996 which has same engine and components as a Nissan Maxima. Replaced expansion valve, filter and remanufactured compressor. I have evacuated and refilled ac system with proper amount of R134. System is cooling but not super cold air. Low side reads 55 psi, Hi side 95 psi . Prior to all of this systme was working OK,but not super cold. I had added refrigerant with sealer and another one with oil, so I think i have overfilled with oil because system did not cool after those additions. I put gauges on the system and found high side too high (65) so I reduced pressure and no cooling after that. During the parts replacements I flushed evaporator and condenser. New compressor had oil already in it. I have put in 20 oz refrigerant now in system with new components.
I suspect that I still have too much oil in the system or my remanufactured compressor is also bad. Air inside cabin is cool, but not super cold. Why are my readings so off still? Any advice?
