Drawing Down a Vacuum
Posted: Sun Jul 09, 2017 7:09 pm
Hi all,
Working with a 1992 Buick park Avenue ( an R-12 car) . I took the AC completely apart and bought new everything: compressor , evaporator, Main Hoses, Accumulator , Condenser, O-Rings. I have R-12.
so I finally got everything hooked back together with 8oz. on Oil in the system as well as some UV dye.
Vacume time: Ist set of gauges took it all the way down to 29Hg but it slowly went flat. I tried another set of gauges and the most if will go is 25Hg on the gauge. I turned it off but it in indeed slowly leaking down to zero.
I'm trying to think of the best way to find the source of the leaks. I hate to sacrifice a can of r-12 to locate the leaks.
Any other ideas that you have?
thanks
thanks
