Intermittent cold air
Posted: Sat Jul 08, 2017 2:39 pm
I recently changed the evaporator, accumulator, and orifice (I added 2oz of PAG 100 in the evaporator and accumulator) tube on my 2001 Jeep Wrangler. I vacuumed the system (held vacuum for 45 minutes) and filled it with 1.5 pounds of R134.
On the day I filled the system it read 35 low side 225 high side. It was about 90 degrees that day. Vent temps were about 49 degrees.
Today (again about 90 degrees) was the first day I used the jeep. The AC started out cool, after about 30 minutes on the road it was blowing warm air. 10 minutes later it was cool again but not for long. The on/off would happen as I drove home.
When I put the gauges on the readings were all over the place. From 43/250 to 75/75..............compressor was cycling on and off every 30 to 60 seconds.
Is there something else I can check before ordering a new compressor and condenser? I am sure both of these parts are original.
