2000 Dodge Dakota with intermittent A/C issue
Posted: Fri Jul 07, 2017 12:22 pm
So here is the condition:
1. First turn on ac, works fine... at 87F ambient, lowside = 28 to 30 psi, highside = 195 to 205psi, blows 58 to 60F air into truck.
2. After running ac for about 10 minutes if you turn it Off, then wait 2 or 3 minutes and turn it back On, compressor clutch does
not engage and there is NO ac.
3. If you turn the ac Off and turn truck engine Off and wait 10 to 15 minutes, then restart truck works fine again.
One Other symptom I have had is when I turn it on, it comes on blows cold air for about 5 minutes then starts blowing warm then hot air.
If I turn it off and leave it off for 5 to 10 minutes then turn it back on it usually does the same thing again. Compressor obviously does work,, but what component(s) in the system might be suspect with this type of operation ? Thanks .....
