Reviving 1984 Isuzu PUP AC
Posted: Mon Jul 03, 2017 1:56 pm
It's been a long while since I've been on here. I'm trying to revive an AC on a new to me 1984 Isuzu PUP that hasn't had the AC working for several years. It still has some pressure on it but not much Freon in it, just enough to be positive of about 40 pounds. I pulled a vacuum on it and it held well so I charged it up with 30 oz. measured of my R12 that I had been saving. As soon as it was turned on the low side went into a -25 vacuum and the high stayed at about 100 pounds. I figured that it was the expansion valve stuck. I've had this same issue on other PUP's that I've worked on. I recovered most of the R-12 for later use. I replace the valve with a 4 Season. I lost a little oil while working with the evaporator out so I added 2 oz. of oil, thinking that after 32 years that it has lost some oil also. I checked the Thermostatic Switch while it out in a glass of ice with a lot of salt and it was clicking on and off. I did not flush the system. As I was putting the lines back on the evaporator I noticed that the opening of the high pressure joint was about half closed. These are flare joints. After checking both sides of the lines. It was some substance that was hard and a dark tan in color. I had to use different size drill bit to clean both lines to their normal ID. Was this from a sealer some one may have added to the system? Knowing the guy that owned it since new, I wouldn't put it passed him.
Outside temp is 96 degrees today. After cleaning and reassembling, I pulled a vacuum down to 400 microns and that held at 550- microns for about 20 hours. So I added 1 more oz. of oil. System requires 5oz. And loaded 30 oz. of R-12 into the vacuum before cracking up. The pressure at idle are 50 on the low and 250 on the high. This with a big fan on the evaporator to cool. There aren't any shields around the fan on these PUP's, they were add on systems at the dealers back then, even though they are the AC that came from Isuzu. If I remove the fan the high side can go up to almost 400 pounds while the low stays about 50 pounds. If I run the system at about 2,000 RPM, and with the extra outside fan on the front, the high side comes down to about 250 and the low stays about 45 to 50 pounds. But the compressor will cycle right frequency by the Thermostatic switch like it was trying to freeze up. I have not tried it on the road yet.
How much temp drop should the condenser have across it. I have about 15 degrees. Spraying water on the condenser really drops the high and low side really quick so it act's like not enough air across the condenser. I thought it should be in the 20 to 25 degrees range. If someone added stop leak, I'm wondering if the condenser and drier are stopped up. I see a few bubbles in the sight glass but I did put the requires 30 oz. in. Major parts aren't easy to come by for these old PUP's. Any suggestions on getting the pressures down.
GeraldK4NHN
Cayce, SC
"One test is worth a 1,000 opinions"
GeraldK4NHN
Cayce, SC
