Back story: Owner attempted his own A/C repair using box store cans with stop leak (YIKES), and charged into atmospheric pressure. Said the gauge on the can was buried in the red (no surprise there). Compressor clutch sheared the rubber damper, and it's movement feels choppy - new OE replacement compressor should be here this afternoon, and I'll be starting the job tomorrow. I've got old equipment I can use and not worry about stop leak screwing it all up.
Looks to be a TXV system, which I did not expect. The TXV looks accessible right at the evap opening in the firewall - going to check it out for kibbles and bits (hoping not, as I didn't prepare for that).
Said the comp got real loud for 3 cycles, then quit.
Main question is the capacity, and of course if you guys have any additional info, feel free to post it - I'd appreciate it.
Thank you all in advance.
