UV Dye Work If System Has A Leak And Compressor Not Kicking On?
Posted: Wed Jun 28, 2017 9:08 pm
HI all,
I have Mazda 3 that has had an odd leak for a year now. A month ago as the summer rolled in I evacuated the system at a shop. I then took the car and vacuumed the system for 30 minutes and let the system sit for an hour to make sure it was leak free. I then refilled the system and the A/C was ice cold for over 3 weeks. I then parked the car in the driveway for a few days (Very small pitch on the driveway). Today the car's compressor was not kicking on. I know I have a small leak somewhere, I am imagining that the small pitch must be causing the freon to leak a higher rate. The car has been parked on flat ground everyday for 3 weeks no issue until this past week.
Now I picked up an dye/oil injection system that lets me add oil or dye manually, no gauges needed (I have the gauges mind you). But since the freon pressure is not high enough now (Since the compressor isn't kicking on), will putting dye i the system work without raising the freon pressure back up to the point where the compressor kicks on and cycles?
