1985 Chevy Crew Cab
Posted: Mon Jun 26, 2017 8:54 pm
I recently acquired a 1985 Chevy Crew Cab (3+3) truck. It started life with a 454 but it now has a 6.2 diesel. It is factory AC equipped but most of the components are missing. I am doing some research on the best way to implement a good 134 system. I plan on using a 16 x 28 parallel flow condenser, new accumulator/receiver/dryer and evaporator. I need some thoughts on the compressor.
I picked up some brackets (side mount) for the 6.2 that came with a York 488-22011 (244) compressor from an 84 K1500 (similar to the image below). To my knowledge, GM never used a York like this so it may have been dealer installed. The HR6 and A6 compressors used in these trucks mount with different brackets. In any case, I'm just happy I can mount a compressor. Since this is a Crew Cab, and I live in AZ, I need a compressor that can move enough freon to cool effectively. The Sanden 508 is probably too small, so I started looking at the Seltec TM-16HD Compressor. Is this a good compressor? Will it be sufficient to cool the large cab and work with the large condenser?
Lastly, I don't have any hoses and may have to have some made up. I think there are some replacement AC manifolds for these squarebody's but from what I can tell, they mount differently to the compressor unless there is an adapter to attach them to the TM-16HD.
I hope I'm on the right track, any thoughts or suggestions are welcome at this point. Still researching so haven't fully committed to anything just yet.
Rick
Rick
