Evaporator temps around 70 degrees, vent temps only 45 degrees at best
Posted: Sat Jun 24, 2017 12:12 pm
Hi everyone, I had another thread on here recently, and after replacing all A/C components this weekend, I have no improvements in outlet temp. Here is the history:
2006 Lincoln Navigator w/rear (aux) A/C. Bought it in April 2016, with 110k on the odometer. Seemed to be taken care of pretty well.
Summer of 2016, I noticed the A/C wasn't performing well. Especially when I wasn't cruising down the highway for a bit. I added R134 with a quick re-charge kit, and low side pressures wouldn't come out to where they should be in the 85 degree (Fahrenheit) ambient temperature. Added more refrigerant and ended up blowing the seal on the front of the compressor. I then did the following:
Installed a new Four Seasons compressor
Installed a new condenser
Installed new Four Season TXV's (front and rear)
Installed new Four Season drier/accumulator
Installed all new o-rings
I had flushed the lines and the evaporators, and blow them dry with dry air @ 90 PSI. The new compressor was completely drained of PAG oil, and I installed the compressor along with the condenser, drier, and TXV's. Filled the compressor with dyed PAG 46 oil (14 oz, the per the specifications) via the low pressure line. Took the truck to my buddy with a Snap-On A/C machine to do a 30 minute vacuum and filled with 3.6 lbs of R134. In 78 degree ambient temp, truck wouldn't get lower the 50 degrees outlet temp while idling, nor lower than 45 degrees while cruising down the highway. Didn't matter how many hours I drove with the A/C blasting.... 45 degrees outlet temp was the best I'd see. The warmer it got outside, the poorer the A/C system performed. On 90 degree days, I was only seeing 50-55+ degrees outlet temp on recirc mode.
Frustrated with the poor performance of the A/C system after everything I did late last year, I just ordered all-new everything:
Motorcraft evaporators with gaskets (front and rear)
Motorcraft TXV's (front a rear)
Motorcraft compressor
Motorcraft condenser
Motorcraft muffler line
Motorcraft accumulator/drier
Motorcraft fan clutch
Motorcraft fan blade
Motorcraft blend door actuators (2 for the front [dual zone climate control] and 1 for the rear)
Motorcraft evaporator temperature sensor (front)
2 - 12" puller fans mounted to the back side of the condensor (to hopefully help with outlet temps while idling)
All lines under the hood were brand new this time, so I flushed the lines that ran to the rear A/C system, blew them dry with dry air again, installed the evaporators, TXV's compressor (did the same as last time--- drained it completely before installing it), installed the new condenser and drier. I was sure not to allow the drier to be exposed to the atmosphere after unboxing it. It got connected the the sealed system immediately after install, once I removed the shipping plugs from the lines. I added the 14 oz of PAG oil again, and once again, took the car back to my friend. He did another 30 minute vacuum and charged with 3.6 lbs again. 83 degrees outside ambient temp, and pressures were spot on, but the system would only get to around 52 degrees outlet temp while idling and still only as good as 45 degrees after driving with the system full-blast for a while out on the highway.
I beyond frustrated with this A/C system. I pinched off the heater core lines on the front and the rear to see if heat was somehow bleeding past the blend doors) and both the front and the rear A/C system were within 1 degree of each other on the outlet temp, but neither system would get below 47 degrees yesterday while driving. I then checked the rear evaporator temp (it's easier to check than the front, since I still have the interior panel removed) and it was around 70 degrees. I had checked the front evaporator a couple months ago and it was only around 68 degrees. What gives???? And how is it that the evaporator temperature is only around 70 degrees, but the outlet temp at the time was around 50 degrees???? Should the evaporators be a lot colder???? They didn't feel cold at all. And the heater core lines were nice and cool since the lines were pinched off, so there's definitely no heat bleeding into either evaporator plenum. We added a little more refrigerant and no improvements, so we evacuated the system and re-charged it back with 3.6 lbs.
The recirc door for the front A/C is definitely operating properly and the rear A/C can only recirculate cabin air (it has no means of bringing in outside air). I just don't get it. Do the TXV's need to be adjust or something????
I know several people will say 45 degrees outlet temp is just fine.... but I've never owned a Ford (and I've owned plenty) that won't put anywhere from 38-40 degrees outlet temperature sitting still, let alone while driving down the highway for a while. No other car I've owned out of the 13+ cars have I had to do any work to get cold enough temps to come out of the vents. My '98 Expedition was 39 degrees all day long and I never even replaced anything on that A/C system. And that 45 degrees outlet temp is unattainable once it gets hotter outside. Outside air is definitely not getting into the evaporator plenum so nothing explains the poor performance I'm seeing. Does anyone have any ideas at all???? Thanks a bunch!!
-Andrew
-Andrew
