R134a cooling - acceptable or is there a problem?
Posted: Fri Jul 22, 2016 9:47 am
Vehicle: 1988 Chevrolet 3/4 Crewcab (73-87 body style)
Engine: 2005 GM 6.0L V8
Compressor: Denso 10S17F
Orifice Tube: Ford Blue
Condenser: ACDelco Parallel Flow (156960)
Temperature: 93F w/ 60% humidity
High side: 325-350
Low side: 45-50
Center vent temp, at idle, max air, doors open: 60F
Center vent temp at 55mph, max air, doors closed: 52F
Hello all,
I just completed my A/C system on my engine swapped 1988 Chevrolet Crewcab, and I have to admit, I'm not entirely happy with its performance. The system is all new except for the evaporator, which was flushed. I used a Ford blue orifice tube, 8 oz of PAG46, and the shop that charged it said they only had to put 32 oz of R134a in the system. I vacuumed the system immediately after buttoning everything up, and the accumulator was the last thing installed. The A/C shop also vacuumed before they charged, per standard procedure. The accumulator and outlet fitting are sweating, and the suction line fitting at the compressor is cold/cool as well. Compressor discharge is hot, condenser outlet is warm. The evaporator inlet, at least where I can feel before I run out of visible tube, doesn't feel all that cold, just cool. At idle, pressures were about 45-50 low side, 350 high side. I am running 2 LT1 Camaro e-fans with proper fan shroud, and they come on with A/C pressure as they should (controlled by the PCM). Spraying water on the condenser dropped it to ~300-315, which is somewhat expected? At 1500+ RPM, the pressure would quickly rise enough to cut off the compressor via my HPCO (~455 psi, according to the spec). The cooling is OK, but seems like it should be better with a parallel flow and modern compressor. Once the sun went down, I took it for an extended highway drive, and the lowest temp I saw while moving was 51-52*. It actually got slightly cooler at idle - 49* or so. Temps were still in the 90F range.
Am I just expecting too much from the system, or is something wrong? Based on some troubleshooting guides I saw, high low side and high high side pressures could be caused by a non-sealing orifice tube. While filling the evaporator with some of the oil charge, some started to run out (evaporator line is level, shouldn't have tried to put oil in it, haha), so I used compressed air to blow the oil into the evaporator, and I accidentally "sealed" the blow gun against the tube. Did I blow my o-tube backwards into the liquid line, possibly?
Let me know if there is any other info I can provide.
High side: 325-350
Low side: 45-50
Hello all,
