V5 shaft seal leak
Posted: Fri Jun 16, 2017 6:25 pm
Replaced shaft seal late last summer and it seemed ok. Held over winter but started using it this summer and found clutch wet with oil again. This AM found clutch wet with oil _again_ so tore it down to get a better look at shaft seal area since it only seems to leak while running.
Assuming it is leaking from the shaft area, is this shaft too far gone from salt/corrosion?
