switching from HT6 to a different type of compressor
Craigs2
Post by Craigs2 »
The Delphi 6628 compressor on my 17 year old Silverado is leaking according to a dye test.
I was planning to replace it with a UAC CO 20145C. The UAC website says that the CO20145C is an acceptable replacement and is an HT6, although they do not list the Delphi6628 under its cross-references.
But UAC also prepared a technician service advisory on the HT6 compressor:
https://uacparts.com/Downloads/The%20Ge ... r%20v3.pdf
In the advisory, the suggest two alternatives: CO 20151C and CO 4440C
Which would you recommend:
CO 20145C (HT6)
CO 20151C (Nippondenso-like alternative)
CO 4440C (Sanden-like alternative)
If I installed one of the alternatives, would I need to change anything else on my system?
