1992 NSX AC Refresh questions
Posted: Sun Jun 04, 2017 6:20 am
Hi All,
The car: 1992 Acura NSX. 85k miles, still running r12, just had it recharged and is blowing cold. There is a groaning/moaning sound coming from either the AC pully or the compressor-only happens when the AC is switched on. I'm assuming for now that it's the compressor, but am diagnosing the pully vs. compressor next weekend to know for sure. I'll also perform a dye test to look for any leaks.
The situation: This is my daily driver in south Florida and I want to be ready to swap the compressor before it dies completely. I'd like to stay with R-12 as well, and am comfortable with getting the EPA cert and the higher price of the refregerant vs. 134a. When the compressor is replaced I'll use the time to disassemble the system, flush all hoses and the 2 front condensers and replace all seals that I have access to. I don't want to deal with the evaperator unless necessary-it requires removing the dash.
Question 1: The NSX was built from 1992 to 2005, remaining mostly unchanged. In 1997 the compressor was improved to better deal with the r134a. Is there an advantage to using the post 97 compressor (supposedly more efficient) while sticking with the r12 refrigerant? South Florida in the summer is both hot and humid.
Question 2: Is there anything else I should consider, or any steps that I might miss?
Thanks!
Thanks!
