Please confirm coil fault
Posted: Wed May 31, 2017 12:06 pm
Hi,
AC clutch does not engage despite gets juice and good ground. Also clutch turns fine by hand. The following resistance readings are with compressor in vehicle and the coil disconnected (from bat. & to gnd.) at connector on top of compressor. A= anode fr. bat.+, C= cathode to bat.- & H= housing of mounted compressor;
A to C = 2.7
C to H = 2.7
A to H = 0.7
(When I touch the tester probes directly to each other I get 0.7)
Additionally (with both coil wires still disconnected) when I run a 14 gauge jumper wire from bat.+ to A it gets very hot very quick before I quickly pull it.
Interject here that previously a jumped fan belt had partially stripped both coil wires but not too bad. AC was not on at the time and the wires were easy to re-insulate after which the AC ran fine for a month. Current problem started intermittently but now seem permanent.
My thought (and hope) is that compressor, clutch and coil are OK but there is a short to the compressor housing in the inch or so of anode wire that turns to the coil between the pulley and compressor (not able to view it). It could have started when the fan belt "hit" the wire but anyway something is wrong now. I don't know if the diode at the coil plays any part here.
Thanks for reading and your comments will be greatly appreciated as I was unfamiliar with many of the terms used here a week ago.
A to C = 2.7
C to H = 2.7
A to H = 0.7
