Testing for leaks
Posted: Tue May 30, 2017 7:00 pm
				hi All,
1992 Buick Park Avenue - I'm trying to revive my Grandfather's car that has been sitting for 10 years since he passed. I know for a fact that his AC worked before it was parked. It is still an R-12 car and I have several cans of R-12 left. The Freon leaked out over time because compressor won't engage now. I saw some oily looking fittings at the Accumulator so I opened those up and replaced the O-rings. Some dye and oil burped out of the first connection that I opened.
After tightening I put a vacuum on it and it would show 29.X worth of Hg but when I turned off the pump it would be at 0 Hg in about 10 minutes.
I saw a little dye out of the Low pressure valve and a little on the body of the compressor. I am still not real convinced where the leak is.
I suppose I could add more dye and partially charge with some R-12 but I hate to leak test with the precious R-12. Would it be a bad thing to add R134 and leak test with it? (since its cheaper)
thanks Rob
thanks Rob
 - now I know why.
  - now I know why.
