Diagnosing ac problem 2007 jeep liberty
Posted: Tue May 30, 2017 8:35 am
Hello everyone, I'm looking for some tips on identifying the problem with my 2007 jeep liberty's ac system.
I'll start with the heat in this vehicle works well, blower motor functions well on all settings. But with ac on coldest/highest setting, temperature is not cold.
I assumed the system was just in need of a charge but the gauge from my ac pro can shows that I have a good charge on the system. The compressor clutch seems to be engaging properly. Also I should mention that the high pressure line is hot to the touch and the low pressure line is nice and cold to the touch.
Does this mean that maybe the condenser or evaporator coil is bad?
I'm new to the forum and inexperienced with fixing problems with ac. I do not have the proper ac tools. I would consider investing in the proper tools if I feel it would be a smart move. I realize that if indeed I do need to replace the evaporator coil I'm in for a big job and maybe it's better to take it to a shop.
I try to be as much diy as i can be and any knowledge I can gain on this topic would be a plus. Thanks for reading and I really hope to get some feedback!
