2000 chrysler sebring JXi/AC wont engage, there's power at pressure transducer
Posted: Sun May 28, 2017 7:42 am
HI. I have a problem with the compressor not engaging on 2000 chrysler sebring convertible, JXi, clean(ish), sort of low miles(101K). The compressor wont engage no matter what I've tried. Haven't tried a lot of electrical testing though. I have replaced the compressor yesterday but this problem was before the compressor replacement.
I only replaced it because it was "time", so to speak. While at it, I replaced condenser as well, along with txv, drier, relay, all the o-rings, and I did this job meticulously. But like I was saying, compressor not engaging was the issue BEFORE replacing anything of this.
One thing I did do(don't get mad), and I only tried it because I've done it a few times, was bypass the relay. You know, sticking horseshoe shaped metal paper clip in the two slots that the relay goes into. But this time, and only this time(every time before it's ALWAYS worked) compressor wouldn't/didn't engage. Btw, I do only leave jumper clip in there for a split second, never for any long periods of time, and it's just to see if compressor will engage. It's never hurt anything before, I don't think it did a thing this time either, it simply didn't work as it always has done before. Anyway, that's a "clue"! I found a clue to what might be wrong! 1 measly clue, not a lot to be excited about here I know, but it's 1 thing I did find wrong.
So now I'm stuck. Not sure what to do or check yet to make this compressor capable of coming on/engaging.
So far I've only done a couple little things electrically. One was check for power at the transducer(it's on the high side line with a pig tail that goes into it) with test light, shows hot at purple/white stripe, wire, and nothing on other 2 wires. It's a 3 wire deal. Purple/white stripe, black/blue stripe and straight blue into transducer. Can I check for ground at the transducer without blowing things up? Or actually, could/should I check for ground there? Or at the relay?? Oh, and fuses are all good.
There was power using a test light, and I only did this check with key on, not the engine running, and the a/c on in the car(green light) blower on high- At the 5 slots the relay goes into, there's power showing at slots, numbers 19 and 39. Test light shows nothing else in the other three slots, 20, 21 and 31.
Can there be a ground missing somewhere you think?
Thanks for any guidance from here!!
